The idea around removing grease from the spool bearings and oiling with a high quality oil like ReelX/CorrosionBlock ReelSpeed/Quantum Hot Sauce etc, is to help reduce the start-up inertia of the spool (getting it up to speed easy and quick)...after that, the Magnetic Cast Control System, is utilized to "balance" the max spool speed/rpm's, so that the spool only deliver the amount of line on freespool. that the sinker/bait combination, can keep on , taking away !good day.
why wash out the ghries in spool bearings and oil it with a light oil to speed up the spool and then slow it down by magging it.
Is the overall effect a better controlled high speed spool?
In this way, slack loose coils that end up as an overrun on crow's nest, are eliminated !
Feel free to request any additional info you might need !
Cheers !
_seal1_
Cheers !
_seal1_
PI....het jy al jo kat rolle gemag?
All of my reels are magged now.
However, most occur at the end of a cast.
so, to kind of sum up.
oil in bearings reduces the initial inertia of the spool - thus more energy is spent spinning line of the reel.
less friction from the bearings due to thin oil and less energy wasted to overcoming inertia lets you attain a higher spool speed which causes more braking power from the secondary induced magnetic field.
almost a paradox - but i assume (putting makeup numbers to it):
if ghries gives you say max 100rpm with 10 units breaking power this might relate to 90m distance while thin oil might give you a max of 120rpm with 20 units breaking power which then relate to 96m distance and with more line control. hypothetically thinking.
the downside being that as the weight slows down at the end of the cast the breaking power might become to weak to slow the spool down enough as the weight looses speed and a bit of thumb control is needed to prevent it.
Very informative post,Sealine is blessed to have abounding knowledge freely available.
For what it is worth.
If overwinds occur without fail at the end of the cast it can be remedied by using a slightly thicker oil in the bearings.This will aid the spool in slowing down incrementally as the eddie-current of the magnets start ''fading''.
Another ,perhaps less desirable option is to either have less line on the spool ( minus 50 meters can make a substantial difference),or to up the diameter from (for the sake of the explanation) ,from .45mm to .50mm.
In the case of upping the line diameter ,the net result is purely that after the cast the spool will become ''smaller''sooner due to the thicker line that has departed. This 'smaller' spool can thus throw less line per revolution than a spool of bigger circumference(more line left on it).In brief,the sinker continues to tow the line until touchdown, and therefor no overwind occurs due to excessive line leaving the spool as opposed to what the sinker can tow.
In the case of using thicker oil on shielded bearings, basically the following happens inside the bearing during the cast.
The centrifugal forces 'throws' the oil away from the ball-racers during the cast.Obviously the force is highest at optimum RPM,which is at the onset of the cast.(from the moment the sinker departs it cannot generate more speed as there is not any more energy applied).
As the spool starts loosing momentum, the oil starts ''seeping''back between the ball-racers(because of less centrifugal force) and thus starts slowing the bearing down,which in turn slows the spool down,and thus prevent excess line(more than the sinker wants)from leaving the spool.Hence no overwind at the end of the cast.
If shielded bearings are cleaned and lubed correctly,the oil will last surprisingly longer than one may think.(if not wading,(dunking) which may either wash out oil or negotiate the properties iro viscosity.
Grease,does not share the above properties with oil(although they are great for inhibiting rust).Magging a reel is a great way of spool control,and if you can combine it with some assistance from using oil,you will have the best of both worlds.
It is true that mags can be used without any assistance from oil-braking,such as in tournament casting reels with ceramic bearings and zero oil.However that is a very specialized application.
In my humble opinion the confidence of not fearing an overwind anymore, is also an added contributor to extra distance gained.
Net my 2 pennies .
::tight:
